wireless connection
superloon
wireless connection
hi iv just setup my first wireless connection i am new to this its a netgear router when i am tryin to download some thing even just a tool bar i get internet explorer cannot download the connection with the server was reset any ideas
1 REPLY
wireless connection
Are you using wirelesses or cable if its wireless is the signal strength ok? what is the result of ipconfig /all post it so we can see.
Is IE set to dial a connection? Can you ping 194.119.131.66 and www.plus.net?
