will we all get free upgrades to 4 MB soon ?
will we be getting free upgrades to 4 Mbit or more soon ,
Malibu .
It depends on what you mean by soon.
other than the trials, which are ongoing, the rest of us mortals wont see higher speeds until the latter part of the year, unfortunately.
It also depends what account your on.
If on £21-99 then it will cost you to upgrade
If on £29-99 then free upgrade to 4 Mb
If on £39-99 then free upgrade to 8 MB
Always assuming your line is good enough.
Unlikely before Sept when the BT high speed trials finish and even then it may be later still. So if you are on the 29.99 or 39.99 product you're wasting money and need to do the free regrade to £21.99 that PlusNet is offering all broadband customers on the premier accounts. You can then upgrade for free once the decision about faster speeds is known.
shall i go out on a limb and assume that the teleworker accounts (70/month) also are going to get free upgrades to 8meg
As if. That would seem too easy for this lot atm.
I surpose plus.net will email us if our lines can go above 2mb I hope so
