why is it ? changed to bbyw and now speed has been limted to
zambezi
can anyone help me,
yesterday was changed from payg to bbyw option 2 , as soon as i had reset router ive been crawling the web,
lookimg at my connection setting it says my bb speed is 500kbps
but router is connecting at 8mbps
is there anyway of getting this to jump or do i have to do the router reset for the next few days ?
any help much appreciated
Mand
Your speed profile was updated by BT just after 3am this morning.
A BT Speedtest will confirm this for you. If the sync speed has returned to normal the throughput will increase over the next few days.
It's the way Max was designed unfortunately, you can find more information here should you wish.
zambezi
thanks for the reply guess ill just have to wait then Wink
thanks again
