why does d'stream margin need a reboot to e-set it
My downstream margin generally sits at 20 to 26 which is fantastic news for upto 8mb speeds. Sometimes however it drops to below 15. if I hard reboot the router comes back on at the higher levels again. Line attenuation 44.
1. Why does a re-boot make the difference?
2. what is happening to reduce it that simple hard reboot will fix.
A
1 REPLY
it could be just getting misread by the router. some rotuers arnt calibrated very well. I wouldnt worry about it.
Btw just because ur SNR is 20~26 doesnt mean u will get 8Mbit.
Most people will only see around 6mbit. I i think u'll be in around hte 6mbit mark if ur a 2mbit user already
