whoosh test - what to do with results?
rammie1976
I asked +net via a ticket if they'd do a whoosh test, this is the reply...
"Assigned : Dear ***********,
++ Internal ++
WOOSH errors.
NCAS errors.
try again.
The next action on your Contact Us Ticket is due on Monday 14th November at 6:00am. This ticket will remain open with the CSC - Escalations Team until this time.Additional information is provided below:
Regards,
what does it mean anyone please?
LiamM
It means they experienced an error whilst carrying out the test. Sometimes they take a few tries to work...
It means your line will be re-wooshed around Mon 14th Nov at 6:00am.
JonathanW
That looks like they encountered some problems when trying to woooosh your line, and as such flagged it up to be tried again tomorrow morning.
It looks like they have tried to do one and its failed for some reason, usually a problem with the BT system they use to do them. They've then assigned the ticket somewhere else to have another go later on.
Chris
rammie1976
whoosh.............ooh two for the price of one! Wink
Thanks chaps.
rammie1976
Blimey you guys are like buses....3 of you!! :lol:
Thanks again.
rammie1976
Whoosh - results
Actioned : Dear *********,
Loop Loss 35 dB
This shows you should be able to get 2MB speeds.
Regards,
Also
From 3Com router -
Operation Data Upstream Downstream
Noise Margin 30 dB 31 dB
Output Power 12 dBm 20 dBm
Attenuation 21 dB 36 dB
and off Samknows using phone no & postcode -
You are approximately 2.44km from the exchange (straight line distance).
Whats the best thing to do with these stats please? On another thread someone said I need to get BT to change my records. Exactly what records and who would I contact?
Or should I try Mr Saffron on ADSLGuide as also was suggested?
Thanks.
prichardson
You might want to try Andrew. He does appear to have the best sucess rate at this.
Kind Regards,
rammie1976
Thanks, I'll try that then. Smiley
