which way to go
tonka
which way to go
hi i am running a extension from my master socket in one room to my front room where my computer is ,i was wondering if a more permenant solution in a bt extension was better or a wireless router would be better as i get moderm drops at least once a day,
which way to go
I think you should find out why you are getting drop-outs first. Perhaps start a separate subject.
A wired extension will give the best results. If both locations are on the ground floor, is there a cellar underneath? Ideal for hiding wires.
which way to go
Hi, Firstly please don't open another post on the subject, as it's not required.
What filters are you using?
While a properly fitted extension is neater, it will depend on the quality of installation, cables etc. as to whether you would noticed any improvement. If your extension lead is a good quality one, I'm not sure this would make an large difference by installing a fitted one, espcially over the distances that your talking about.
It could also be a power issue, if the modem is USB, then it'll be drawing power from the PC and this can make them drop their connection at times.
A wireless router is certainly one way to go since, I would suggest a DG834G.
Aaron
tonka
which way to go
hi ,my filters are standard plus net issue at the moment but have some excelsus z-420uk-adyna coming,the extension that i am using is not a reel in reel out one and looks ok as far as i can see.the moderm is usb (voyager 105).
which way to go
You can get rid of that for starters
tonka
which way to go
which moderm do you suggest and how much?is it a case of just pluggin it straight in.
which way to go
Hold on the new modem!
An ADSL modem must be on a USB Root hub on its own, nothing in the second port. Check in Device Manager, Root hub, Action, Properties, Power.
which way to go
The new filter your getting is good. I would drop the modem, and get a router . You'll have a more reliable connection, you won't have to log in, you won't need to have any additional software or drivers for a modem etc. etc.
Oh, and you can add more PC's , PS2 or Xbox etc. with ease.
Aaron
tonka
which way to go
hi ,.new to this game where is device manager?
which way to go
Control Panel, System, (In XP, Select Hardware)
tonka
which way to go
still cant find it sorry doh!!!!
which way to go
Tonka,
What operating system are you using? Windows XP, ME, 98SE?
Aaron
tonka
which way to go
windows xp mate
which way to go
Click Start
Select Control Panel on right section of menu
Select System
Click the Hardware Tab
You will see a button for device manager :-)
tonka
which way to go
as far as i can see the moderm is on a port on its own with a spare root hub and there is two spare ports on my other root hub.
