which adsl router to buy, please help
Hi, Could anyone advise which router to buy for compatibility with plusnet, I have always used a modem speedtouch 330 at the mo.but getting a lot of dropouts and it does'nt reconnect automatically so want to change to router using my Ethernet connection which I understand is better. I have only one pc and have been looking at BT voyager 2091 unlocked on Ebay used at £26:50 inc.postage as you might of guessed a bit dull in these matters I bought a BT Home Hub and now realize it's locked to BT Broadband and I don't want to buy another pig in the poke,Many thanks for any help.
The Netgear DG834G always comes highly recommended on these forums.
http://www.netgear.co.uk/extra/h_wirelessrouter_dg834g.php
The DG834G connects via ethernet and has a wireless option. If you do not want / need a wireless option then the Netgear DG834 is the same router but without wireless.
Both are excellent routers and will work well with PlusNet.
many thanks rustyn77 for your advice will check it out.
Speedtouch 585v6 is a good router, and good for longer lines. Its very tweekable as well. Its done Ok for me.
router
many thanks hesketh14, will check it out
