where to get good filters
bluewhale
I have hssing on my phones , i'm assuming its the cheapo filters i bought
but is it known that wireless routers can also cause hissing on phones?
Assuming it is the filters what and where do people recommend I get some new ones from...
cheers
pete
try
Plusnet Shop
also try
Dabs
However for something as small and cheap as an ADSl filter you might be better going to a local computer shop or even PC World
Alecto
It's worth investing in some decent filters to avoid problems with the phones.
They are not expensive.
I use xf-1e's
which I originally saw recommended on the Pn forum, and which I've been very happy with. You can order them online.
And remember you need one for every phone socket that is in use, including Sky.
