where can i find
where can i find
where i find my contention, stable rate,attenuation.
also i just set up a wireless router and i cant get any details of my connection speed. where should i look, its a buffallo airstation
any help much apprech, ta
1 REPLY
where can i find
Contention depends on your product. Normally residential accounts have a contention of 50:1 and business a contention of 20:1
Your stable rate is here but it is only relevant if you have been upgraded to MaxDSL.
Line attenuation is found in some (but not all) routers and some USB/PCI devices. So we need to know what ADSL equipment you are using. Also see http://www.kitz.co.uk/adsl/frogstats.htm to see if your device is listed.
Can't help with the wireless connections - don't know the product.
