what is going on plusnet?
hi there mr long here
yes my adls line has been going very slow etc..
taking ages to sites to come up and when iam downloading iam only getgbn speeds of 23 k a sec?
but i shoudl be getign 50k or more yes!
what is going on plunet can you please find out etc....
thank you mr long
RE: what is going on plusnet?
is there any support around,things to be slow laterly
what is going onthank you mr long?
I cant play any online games with the speeds as they are let alone host a games server, are we really paying for this sh*te
Ali
Scott - see my reply on the plusnet when are you going to fix upload speeds thread re MTU settings ( it appears to work) - let us know if you get an improvement.
Steve
> Steve
steve what you mean change mtu settings etc..
how do i change them ?
Scott
The following link will take you to the ADSL guide info page for this fix
http://www.adslguide.org.uk/guide/mtu.asp
I recommend downloading the DRTCP software to make the change ( You can download the latest version of DRTCP from http://www.dslreports.com/front/drtcp.html).
Using DRTCP I set the following values :-
MTU speed 1458
I set both of the following boxes MTU and Dial Up(RAS) MTU to 1458.
Don't forget you need to reboot your PC ( not just a restart - I actually had to power down completely and then restart before the settings took effect).
You can revert to the original setting by setting the MTU back to 1500.
Hope this makes some sort of sense.
Steve
P.S - the ADSL guide ( http://www.adslguide.org.uk/)
contains lots of useful info reagrding this and many other issues - look under forums at the plusnet site).
> Scott
> MTU speed 1458
> Steve
when I say look under forums at the plusnet site - I mean look under the forum option at the ADSL site and from there scroll down to the plusnet ISP forum.
