voyager 210
voyager 210
Can I connect and get internet connection to 2 PCs.
At present I have the voyager connected to one computer using the USB socket, can I connect the other PC using the ethernet socket in the voyager
Thank you
1 REPLY
voyager 210
Yes, you can use both connections at the same time.
It's not an ideal setup as I would recommend investing in a 4 port ADSL Modem/router and not use the USB connection if you intend to use faster than 4Mbs speeds.
