usb - safely remove hardware !!
hi
thoroughly impressed with adsl but...
can any one explain why i have a permanent "safely remove hardware" icon in my system tray. it's very annoying. none of my other usb stuff causes this icon to appear
any help would be appreciated. thanks in advance. karl
RE: usb - safely remove hardware !!
I get it aswell it's been there for months, I just ignore it as it has never caused me any problems.
Go to System Properties and then into Hardware and Device Manager, can be accessed through control panel, find the hardware that is appearing in the Safely Remove Hardware icon and double click it to bring up its properties and then click the Policies tab. And click the option 'Optimize for quick removal'
That should get rid of the icon, you may need to reboot before this takes effect though.
