upstream bandwidth
upstream bandwidth
Implementation of connections between adsl users and plus network edge.
Customer downstream data is transferred from the network edge through our internal network over dave's old tv aerial cable.
Customer upstream data is routed direct to aviary number one where our highly trained pigeons pick up the packets and transport them to aviary number two. From aviary two outwards the upstream traffic is carried over the same high performance network as the downstream traffic.
Downstream 323 Kbps (40.4 KB/sec) 371 Kbps (inc. overheads)
Upstream 49 Kbps (6.1 KB/sec) 56 Kbps (inc. overheads)
:lol
RE: upstream bandwidth
funny as fvk
hi lyndon
heres mine if you think u got probs
Direction Actual Speed True Speed
Downstream 240 Kbps (30.0 KB/sec) 276 Kbps (inc. overheads)
Upstream 19 Kbps (2.4 KB/sec) 21 Kbps (inc. overheads)
> :lol
Ged. Its has happened again. Its the memory. It needs refreshed. Can you oblige?
> funny as fvk
why thank you
i know i've got problems. your speeds are a bit poor as well :-)
espresso_mick
Downstream 450 Kbps (56.3 KB/sec) 517 Kbps (inc. overheads)
Upstream 305 Kbps (38.1 KB/sec) 350 Kbps (inc. overheads)
errr not to sound like a n00b, but how do ya test?
Downstream 76 Kbps (9.5 KB/sec) 87 Kbps (inc. overheads)
Upstream 38 Kbps (4.8 KB/sec) 43 Kbps (inc. overheads)
i just got these amazing speeds go to www.adslguide.org.uk and follow links to speed test.
Judy,
What speed do you get reported by PlusNet's speed tester at http://speed-test.plus.net.uk?
Tim
Got u all
Downstream 404 Kbps (50.5 KB/sec) 464 Kbps (inc. overheads)
Upstream 10 Kbps (1.3 KB/sec) 11 Kbps (inc. overheads)
> Got u all
So how am i ment to be a DJ on #gameon-radio on QNET with that hey?
> Judy,
> Tim
i just did the plusnet test
"Your current bandwidth reading is:
115.30kbps
which means you can download at 14.41 KB/sec. from our servers"
better than adsl guide says, but my pc is behaving exactly like it did with 56k so i believe adslguide's figure now reporting 5.5 kb/s each way.
Sad
jk
> 115.30kbps
> Sad
> jk
Judy,
Register free at www.dslreports.com, and then run a line quality test. This will show what packet loss you're experiencing. You will need to become pingable for this test to work.
Have you raised a ticket with PlusNet support about your speeds?
Tim
