upgrade
upgrade
hello i am considering upgrading to 1mbit (the home premier account) however i have some points i would liek to clarify:
1) it costs £29.99 per month and there is another activation fee of 70 quid to be paid (on a monthly contract)?
2) i can keep my existing ip's and their rdns setup?
3) will there be any downtime involed?
upgrade
What product do you currently have as this will determin the costs involved in the upgrade and allow us to answer your questions fully. Also do you have your own ADSL modem/router hardware?
upgrade
hi, i am currently on the self-install home 512k connection ..i think thats the name of it (its not the account type which blocks p2p).
Yes i will be using my own hardware (solwise sar 110 router).
upgrade
The upgrade / regrade prices are listed in the FAQ page here. It will depend on what you want to change to and whether you go for a monthly or yearly contract.
Now to answer you Qs
1) Home 512K -> broadband Home 1Mb premier (monthly) will cost £52.88. It does not require a new activation fee just a regrade fee which is cheaper.
2) I'm not sure if you keep your existing static IP as PN may use separate IP ranges for the new products. I would guess you will keep it but I'll let PN confirm this as no-one has asked this yet..
3) The downtime should be about 2 hours and the switch usually occurs overnight
csogilvie
upgrade
A yearly contract will cost £41.13 as well...
I would imagine you'll keep the same IP, although a new range has been added recently, so like Peter, I'll bow to TPTB.
