upgrade to 1mb ???
upgrade to 1mb ???
could someone please answer the following questions?
If you have a 512kb connection and want to upgrade to the 1mb connection why do you have to do a disconnect then reprovide? I know that with some of my friends with other isps all they had to do was send and e-mail asking for the upgrade. it was then just actived!! all they had to do was disconnect for 30 minutes then reconnect again. Why can't plus net do this?
upgrade to 1mb ???
Very good point.
However, I don't see how this is true. I do not belive there is a upgrade path with BT yet (properly).
Can Support shed further light?
upgrade to 1mb ???
Very good point.
I think Phillip that you are correct here.
There is some work to be done by BT involving the upgrade but I don't beleive that it is the same amount of work as providing a new installation from scratch?
I think that if there was a proper upgrade path it should be cheaper than a new install.
Maybe one day BT will get their act together :?:
upgrade to 1mb ???
according to one of my engineering friends it is just a simple case of telling the controlling software to allocate more bandwidth to the users port in the exchange. maybe someone from plusnet support will be able to elaborate on this?
upgrade to 1mb ???
This is likely very very true, and more probably what happens.
However, youa re talking about BT here, that make a song and dance about everything.
To migrate from engineer install, to another provider, on exactly the same product, you have to cease and re-provide. This is a "what what?" issue. Only the ISP proving, and a regular migration needs to take place. The fact a router or modem is issue is usualy irrelivant.
