upgrade and wireless
Folks need to know if my line is being upgraded would it mess up my wireless set up ??
I cannot get on line usin my wireless and have to use wire to connect
its a new new pc with wireless installed and dont want to go and call dixons service center if its down to plusnet and the upgrade
have got a ticket going but no reply as yet
1 REPLY
No if your line is upgraded to Max it will make no difference to your wireless setup. You router will just sync at a higher rate.
