unable to get specific web address with BT Voyager2100
pennbank
I am trying to get the Ryanair web site on the web,but am unable to. All I get is Internet Explorer cannot display the webpage.
I can remember having a similar problem to a different website and cannot remember how I fixed it.
Think it was something to do with My BT Voyager 2100 Router.
Any one had anything similar ?
Plusnet Staff
Plusnet Staff
Fixes: 159
Hi there
This thread should help shed some light on your problem, it appears that ryanair are having some DNS issues today.
 Chris Parr
 Plusnet Staff
pennbank
Many thanks for the quick reply, I will watch other thread, Have been trying for a few days. May be because of ther £10 one way offers.
Also I see that Tiscali has mail problems.
pennbank
Had a senior moment, Can now remember that I was at one time unable to get access to Sweet tomtom.com which is the home page of my sat nav to update. The fault arose in the Voyager 2100 adsl. Changed the MTU configuration to 1500 and the site worked fine. :shock:
Forgot to mention how extremley helpful Plus Net were at the time, although the answer did not come from them. (came from similar punters on a sat nav forum.
Please can we use this thread as suggested by Chris;
http://portal.plus.net/central/forums/viewtopic.php?t=56435
Jonathan
aka Chilly
