tracert result shows different
vic_newey
After raising a ticket to point out that altho I am on premier & pay £21.99 Winmtr & tracert show that I am still on homesurf restrictions . +net support tracert did not show the same as mine & altho they confirm 'yes you are on premier ' how come my tracert still shows homesurf & my connection at certain times seems throttled. I do not have 'suf' enabled in the portal either
my tracert result :-
Tracing route to portal.plus.net [212.159.8.137]
over a maximum of 30 hops:
1 * * * Request timed out.
2 24 ms 23 ms 23 ms lo0-homesurf.pth-ag3.plus.net [195.166.128.65]
3 23 ms 23 ms 23 ms ge0-0-0-405.pte-gw2.plus.net [84.92.4.18]
4 24 ms 23 ms 23 ms gi5-0-22.pth-gw2.plus.net [212.159.4.5]
5 28 ms 29 ms 28 ms atm0-1-0.ptb-gw1.plus.net [195.166.129.246]
6 29 ms 30 ms 29 ms vlan18.pri.ptb-gw4.plus.net [195.166.129.130]
7 30 ms 29 ms 29 ms if2.ptb-al1.plus.net [195.166.129.39]
8 29 ms 29 ms 29 ms portal.plus.net [212.159.8.137]
Trace complete.
The tests Plusnet perform are from the oposite end of the connection (to you, rather than from you), this don't show the Homesurf routers.
First off, I suggest enabling the Surf option and maiting 30 mins or so, then reconnect.
Then disable it, wait 30 mins and reconnect.
If you still see the same problems then, reraise a ticket and reply here.
vic_newey
I tried that already to no avail, my current ticket is still in the pot but not had a reply since yesterday, I guess If they can't remedy it it will get ignored till it times out.
vic_newey
got reply from CS, it is being further looked into as I definately appear to be on homesurf as I suspected :twisted: Evil
