traceroute
traceroute
I'm having problems with the speed of my connection-
how do I do a traceroute?
lowry
traceroute
  • Open a DOS/Command Prompt window in Windows.
  • Once this window is open, type “tracert www.bbc.co.uk” (or wherever you want to trace the route to) into it.
The following (with different ping times, and gateway most likely) should appear:
Tracing route to www.bbc.net.uk [212.58.224.81]
over a maximum of 30 hops:
1 54 ms 32 ms 39 ms lo1.plusnet.pth-ag2.plus.net [195.166.128.6]
2 40 ms 39 ms 39 ms gi1-2.vlan3.pth-gw4.plus.net [212.159.1.3]
3 37 ms 39 ms 39 ms ge0-1-0-22.ptn-gw1.plus.net [195.166.129.214]
4 37 ms 39 ms 39 ms rt-linx-b.thdo.bbc.co.uk [195.66.226.103]
5 37 ms 39 ms 39 ms 212.58.238.153
6 38 ms 39 ms 39 ms www30.thdo.bbc.co.uk [212.58.224.81]
Trace complete.
To copy & paste the output into this forum or into a contact us ticket – right click anywhere in the comman prompt window and select “select all” from the menu that appears. Then when everything is highlighted, press Ctrl+C to copy it. Then, open whatever you want to paste the output into and press Ctrl+V and it should appear.
I hope that helps,
matt Wink
drw
Trceroute gives * * * etc
Apologies for butting in <g>
When I attempt to run a traceroute - I get a response from the router but then all I get is a series of incrementing number and a string of asterisks
I assume that I have made my firewall in the router too agressive
What setting do I have to reduce to be able to see the results from Traceroute
On the Tweak sp web site speed test it says it cannot ping my machine
Thanks for any comments
traceroute
I believe it's ICMP replies you need to allow. Typically you can confiure your firewall for several protocol types such as TCP, UDP etc, of which ICMP is one.
traceroute
You may want to try WinMTR which shows a lot more info and can be run from windows.
drw
traceroute
Thanks for the answers - I am running OS X on a G5 - so a Windows app will not help
traceroute
hello and thanks for your help
is their a particular web address that is best for doing traceroutes with? or would using the bbc address in your example be OK?
I understand that 'tweaking the MTU' can improve performance and I'll probably try that too. Would buying more memory have any impact on broadband speed? (at the moment I have a mere 256kb....)
Smiley gilbertt
traceroute
You can tracert to any address, usually you do it to a website you can't access or to a games server if you want to find the route it takes and the ping times to it.
Memory has no effect on broadband speeds.
traceroute
thanks matt & peter Cheesy
traceroute
Matt hasn't mentioned this but he is about to achieve fame and stardom by having a tutorial on this very subject posted in the "Tutorials and FAQ" section of these forums Cheesy
So in a day or two there should be a very good write up on this available Cool
lowry
traceroute
It's there now Smiley - click here. It'll be my 15 seconds (amount of time someone will read before finding an error Wink) of fame.
Hope it helps,
matt Wink
