the right records?
the right records?
I want to set my new domain name to point to my static IP I have done this for http://www.my.domain but how would I do it so http://my.domain would also point to my static IP?
the right records?
Enter the domain name in the left hand filed with a period at the end, then the IP in the right hand field.
IE, if you domain is domain.co.uk
Then
Left = domain.co.uk.
Type = A
Pri = Leave blank
Right = Your IP.
the right records?
thanks it works now
