test result
fakesnake
test result
hi just done a speed test, the bt one. this is the result.
Test1 comprises of Best Effort Test: -provides background information.
IP profile for your line is - 2000 kbps
DSL connection rate: 448 kbps(UP-STREAM) 8128 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 1599 kbps
if the router is connecting at 8000 kbps why is my profile at 2ooo? i have rebooted the router it makes no difference. sorry if i have got hold of the wrong end of the stick here, still a noobe at this.
thanks.
sam
test result
I have had a look atv your delta reports and it seems that your sync rate is all over the place and swaps anywhere between 2mb and 7mb, this is the reason for the lowers speeds than expected.
On of the faults guys will respond to your ticket giving you further information on how to raise this, so if you wish to check the ticket in a little while, the info on there may help.
If you have any problems with this info, feel free to give me a yell.
fakesnake
test result
thank you for reply, the support guys said i must have noise on my internal wiring. they said to connect to the test socket in the bt box. the thing is i, dont have a plug on the extension lead to the router upstairs,it is hard wired to the IDC connectors inside the box. but is this not the same as the test socket? as it is direct to the router.
but what i cant understand is every time i look at my sync rate it is allways in 8mb area. i have rebooted the router once a day over the last 3 days and the results are the same.
DSL Status
Connection Status Connected
Upstream Rate (Kbps) 448
Downstream Rate (Kbps) 8128
US Margin 24
DS Margin 9
Modulation MMODE
LOS Errors 0
DS Line Attenuation 27
US Line Attenuation 28
Path Mode Interleaved
DSL Statistics
Near End F4 Loop Back Count 0
Near End F5 Loop Back Count 0
DSL Status
US Margin 24
DS Margin 11
Modulation MMODE
LOS Errors 0
DS Line Attenuation 26
DSL Statistics
DSL Status
US Margin 27
DS Margin 10
Modulation MMODE
LOS Errors 0
DSL Statistics
DSL Status
US Margin 24
DS Margin 10
Modulation MMODE
LOS Errors 0
DSL Statistics
IP profile for your line is - 2500 kbps
Actual IP throughput achieved during the test was - 2093 kbps
Results Image not loaded
Actual IP throughput achieved during the test was - 2281 kbps
Actual IP throughput achieved during the test was - 2282 kbps
Actual IP throughput achieved during the test was - 2216 kbps
does any thing else show up on these stats.
thank you
