tcp +mtu settings
tcp +mtu settings
can anyone suggest best mtu + tcp settins is best to use,as sometimes my connection can be very slow.it can vary from 16kb to 46 kb,mostly about 25kb
RE: tcp +mtu settings
> got mine set at 1458/14180 running at 471/541true
244/280 true this morning dos'nt seem much dif. now.
:bandit:
Yeah, im the same MTU - 1458, RWIN - 14180
Hope this helps
Gandalf and William are spot on for the settings...USE DRTCP to change the settings....then REBOOT for the changes to take place.....
