sygate personal firewall
Has anyone had problems with the free version under winxp?
I have recently rebuilt my OS from the ground up and the only difference is the firewall software the problems seems to be that if I leave the PC on for a period of time I loose my connection forcing me to reboot the modem and reconnect. I may add that the PC and modem control panel still shows a connection
Any help !!!! would be great
Cheers
J
RE: sygate personal firewall
My guess is you are using a USB modem.
This may be the cause of the issue. I seriously sugest upgrading any firmware and/or drivers to make sure the issues ha not allready been addressed.
See http://www.edslguide.org.uk/ for driver details, as ther may be recomended drivers for you to use.
USB modems are known for there power managment problems. They don't allways respond correctly, leaving windows in limbo as to wheather it is connected or not. This also causes two windows flags to be out of sync (one shwoing connected, the other showing "in power saving mode").
Damn - Note to self: Check links before psoting. Note to +Net: Hurry with the edit feature Tongue
The URL should be http://www.adslguide.org.uk/
Thanks but have been down that route already have latest drivers and firm'er'ware However I think Ive solved It I was running my modem through a USB Hub but after reconfiguring it and connecting directly to my USB 2 card no probs so far
J
