streaming video and sound
On dial up I am able to stream sound and video using either Quicktime/RealPlayer or WM player but using broadband they don't recognize that there is a connection.I've looked in the settings of these applications and there is a bit about proxy settings and port for streaming.Does anyone know whether this is the issue and if it is, what values are to be input?
RE: streaming video and sound
sorry don't no wot your problem is,but mine works perfectly and I did'nt alter anything.:bandit:
Your media players should connect to the internet and stream the live content fine m8.
PlusNET doesnt have a proxy server at the moment.
Maybe you should allow your firewall to let them act as a server to connect.
ZoneAlarm Pro and basic has a little pop up box that you give permission to for this etc...
PlusNET dont block streaming on ADSL, i listen almost everyday to Real, Windows media, Winamp and Quicktime and there are no problems this end.
Regards,
Jason
Working Equipment:
Packard Bell I XTREME 9070
Colour Blue/Grey
Intel Pentium 4 - 2.4 GHz -
512 MB Ram
120 GB HDD
Modems: Aztech CNR V.92 56K
D-LINK DSL-200 DIGITAL
DVD, CDRW
Chipset: SiS650
Stereo sound
GeForce 4MX 440 64 MB + TV out
USB: 2 front and 2 back
Firewire: 1 front
Lan: 1 back + (loads more sockets)
Try and connect to this since you're on the same network:
(1)http://www.radiojason.co.uk/live/mpeg/radiojason.mp3
OR
http://www.radiojason.co.uk/live/mpeg/radiojason.m3u
RealOne Player or Winamp should have no trouble connecting. This is a 56K b/b stream.
If you want to try WMP open file location box and enter direct this IP and port: http://64.21.174.66:8052
Post back how it goes.
Good luck.
Jason
Working Equipment:
Colour Blue/Grey
512 MB Ram
120 GB HDD
DVD, CDRW
Chipset: SiS650
Stereo sound
Firewire: 1 front
on my machine at work, whenever I click on streaming video, I can hear my modem clicking on (even though it isn't connecting) and then the video streams from the adsl.
Could be the same problem, but this doesn't help you much !
Bill
thanx 4 help!
however when I type in location, wmp says unable to connect to server.
the site u provided brings a window up with the quicktime symbol but no advancement
i sorted out streaming on wmp and realplayer via zone alarm but qt still doesn't work
thanx
