still having a speed problem
Well I posted a lil while ago saying I was getting slow speeds. Been away a little while but these are the speeds I have been getting for an allegedly 8meg line
17-09-2006 02:11:28 126
16-09-2006 12:01:52 130.7
27-08-2006 10:49:08 131
27-08-2006 10:48:32 131.2
27-08-2006 10:47:52 131.6
27-08-2006 00:49:26 126.7
11-08-2006 19:13:22 328.8
11-08-2006 19:12:44 321.1
These are the settings on the modem
DownStream Connection Speed 1504 kbps
UpStream Connection Speed 448 kbps
VPI 0
VCI 38
I have tried fiddling with the various settings to no avail. Done set up wizard a few times on auto detect. I have done the BT speed test and still nothing better than 127kbs. Any ideas? This is NOT good enough for an 8 meg connection. When I was on the 2 meg in my last house it was fine. I have only had this problem since transferring it
Hi
You say that you have run the BT test and get similarly low speeds.
Therefore I think you should raise it as a fault.
If you could run 3 BT tests, with at least one during the early hours and at least one during peak hours, then you can provide the figures to PN when you raise the issue.
*EDIT*
The above info on BT tests I gave, should actualy read: 1 test during "off peak" ie anywhere between midnight and 16:00 hours the next day.
And 2 tests during "peak" time. ie form 16:00 hours upto midnight.
(Edited after reading a post by COMMS agent James Bailey, stating this to be the case).
*/EDIT*
Here is a link to the new BT test, which saves you from having to change your login details. >New BT speedtest
If you have problems with this new tester (as some have) then go back to the old method. > Instructions
I added the link to instructions just to be sure you were running it correctly. (Some have not been changing their login details, which screws it up).
Hi Ian it is raised ... well was raised a while back but as I had been away i wasnt able to chase it up but i have e mailed them back now. Thanks.
Ok Andy.
I hope you can get somewhere with it soon.
BTW I edited my previous post.
Slipperymack
Hi
For info -
I have used the new BT test site results in a BRAS related ticket today - PN CSC advised me that they would not accept it as it was only a beta site so I had to do the test using the old method.
Really! :|
Nice of you to pass it on malb1, thx.
