speedtouch x64 beta
speedtouch x64 beta
Can anyone tell me how to read the stats from the speedtouch 330 usb modem, just installed the x64 beta driver and im lost...
Can I get 2meg with these stats, cos by the looks of things my line attention is 18, SNR 22.5 downstream? If so installing this new modem has worked wonders coz my old adsl router usally put my line attention around 49 to 51 on a good day.
I noticed this morning the adsl would not sync then it came on about 11.30ish has +net done something or has bt improved my line quality??
<item value="ADSL configuration and statistics" name="ADSL">
<item value="GDMT.A" name="Synchronization mode" />
- <item value="" name="Upstream">
<item value="1" name="CRC bearer 1" />
<item value="0" name="CRC bearer 0" />
<item value="0" name="HEC bearer 1" />
<item value="0" name="HEC bearer 0" />
<item value="0" name="FEC bearer 1" />
<item value="1" name="FEC bearer 0" />
<item value="0" name="Power" />
<item value="9.6" name="Attenuation" />
<item value="5" name="SNR" />
<item value="0" name="Interleaved rate" />
<item value="288000" name="Fast rate" />
</item>
- <item value="" name="Downstream">
<item value="0" name="CRC bearer 1" />
<item value="7" name="CRC bearer 0" />
<item value="3" name="HEC bearer 0" />
<item value="0" name="FEC bearer 0" />
<item value="3.8" name="Power" />
<item value="18" name="Attenuation" />
<item value="22.5" name="SNR" />
<item value="1152000" name="Fast rate" />
</item>
