speedtest
speedtest
Im having problems with my computer connecting at 7.1 mbps and only downloading at 130kbps. How do I go about conducting a Bt speedtest?
Plus I'm having loads of dropped and re- connections, Anything to do with Maxdsl by any chance ?
1 REPLY
speedtest
Dropped connections are most likely due to the maxDSL trailing pweriod which happens during the first 10 days after being upgraded.
A tutorial on using the BT speedtester is here: ADSL: Using BT’s Speed tester service
