speeds rubbish exchange on amber and no fix sheduled
my speeds are down and have been for a while,my exchange is on amber and there's no upgrade sheduled how much longer am i going to have shite speeds?
Would help if you can tell us which exchange you are on.
As for the answer to the rather rude question, whenever BT are able to make the required fixes at your exchange.
This is not off the shelf technology they are using, and it does that time to purchase, configure, test and launch it. The work may even involve digging up roads to install new cable, obviously somthing that can't be done at the flick of the light switch.
the exchange is lofthousegate
That exchange is showing as green.
Are you sure you didn't have the information cached in your browser?
hi acarr,
can you check if there is any capacity/problems for Forest Hill SE26 exchange, where/how do you actually check that ?
Also i have a brand new alcatel/thomson speedtouch 510 v4 ethernet router which i was using with eclipses 2mbit package and never had any speed or connection problems; reading the reviews with connecton drops is this modem ok? i mean is anyone using it without problems...
thnx,
albasoul
go here to check your exchange http://cgi.support.plus.com/exchanges/index.php
