speeds ( once again )
i did a test on the adsl guide speed test as soon as i got adsl, and it was jst a little below, but since then iv not been able to get the top speed of my adsl, and i have been comparing with my friend on the same download and hes on 512k (bt) and i cant seem to get even close to what hes getting? the exchange is fine as its only jst been updated, ( filey exchange )
any1 want to give me an adsl cfg'er? im using the plusnet router starter pack with windows xp home ( all updates )
You need to tweak your MTU and RWIN values to maximize your speed. See the MTU Tweak thread in the ADSL and Broardband forum (at the top) for instructions / info.
Also what is the name of your exchange. Then look it up on Exchange Status Checker to make sure it is at Green.
http://www.adslguide.org.uk/tools/speedchart.asp?id=5f668e7fab4b5338d5f668e7
Sad
[Moderator's note (by acarr): Removed duplicated reply]
