speed !!!!!???
speed !!!!!???
whst is going on, last night i was enjoying 2meg connection speeds and now its dropped to 512 speedsthis morning and afternoon as i`m typing this post, this has been going on/off all the time ever since i down graded to 2meg with 2gig download.
speed !!!!!???
Have you checked the status of your exchange to see if this is a capacity related issue?
http://users.plus.net/exchanges/
In adition. Have you performed a BT Speedtest?
Instructions
On top, does your connection hardware provide line statistics and.or error counts?
If so, can you post these figures.
speed !!!!!???
as for the first link my exchange is showing green on both accounts. as for the second link i will report back later.
speed !!!!!???
snr margin 39.1 downstream 39 upstream dB
line attenuation 21.6 downstream 16 upstream dB
error seconds 0 downstream 0 upstream
loss of signal 0 downstream 0 upstream
loss of frame 0 downstream 0 upstream
crc errors 0 downstream 0 upstream
data rate 2272 kbps downstream 288 kbps upstream
latency fast downstream fast upstream
speed !!!!!???
Those are fantastic line stats, and should cause no problems at all.
Andy.
speed !!!!!???
why is it then when doing a bt speed tester that it is reporting 685kbps and plus net tester is 583 kbpswhich is way under for a 2 meg connection. i am confused.
