speed
Ivan_other
speed
Traceroute Results: http://cgi.support.plus.com/faultreporting/tracert.php?tracertid=2070597
Traceroute Time (24 Hour): 18:50 to 19:10
Traceroute Duration: 20 minutes
Traceroute Packet Size: 64 bytes
Packetloss in Traceroute?: No
Exchange: morley
Problem: Other (Please explain below)
Other Problem Experienced: recently updated my account to 1MB but the speeds i appear to be achieveing are way below expectations? and are also very inconsistent.
Duration of Problem: Less than 1 week
Minimum Speed Achieved On PlusNet Speedtest: 322.0 kbps
Maximum Speed Achieved On PlusNet Speedtest: 380.9 kbps
Average Speed Achieved On PlusNet Speedtest: 351.45 kbps
Account: ADSL Home (BT Install) - 1mb (50:1)
IP Block Size: Single (default)
Ticket Number: None
Additional Information: None
speed
Would you like to give us a bit more info about your setup.
Hardware - Modem /router
Connection to phone line
System / O/S
Mark
Ivan_other
speed
hello,
yes my router is a 3com 11g router adsl access point
operating system is windows xp pro
acer travelmate 290 with intel centrino
i am wireless, hope this helps?
speed
Have you checked out the ADSL Troubleshooting Guide in the Tutorials and FAQ's
http://portal.plus.net/central/forums/viewtopic.php?t=9565
Or Tweaking or changing your MTU
If you read thru the guide above it may help. If not post back and I am confident you will get guidance.
Regards
Mark
