speed woes on 2mb premier
Hello
As you can see something has gone wrong :
15-06-2005 22:57:03 950.4
15-06-2005 22:56:44 867.2
15-06-2005 22:42:50 913.3
15-06-2005 22:42:14 987.7
23-05-2005 21:55:49 1541.5
23-05-2005 21:55:32 1403.5
23-05-2005 21:54:09 1502
17-03-2005 12:05:30 1496.3
Just started last night for no apparent reason
Exchange is in green
Using usb binatone modem, have re-installed drivers
thanks
Are you on pth-ag2
Alecto
which gateway are you connected to?
Other threads imply that there may be a problem with one of them
"pth-ag2 has been giving frequent problems for a while now"
so that might be it. If so, reconnecting to another one might cure it.
I will double check tonight
Hello
I will have to check tonight, as am at work at present.
If I am on that gateway, is there anyway of getting PN to route me through another gateway?
darrenf
Alecto
you just have to keep reconnecting your modem and checking if you're on a different one.
on this one :
I am on this one :
You are currently connected to the "unknown" gateway. This gateway is sometimes known as pte-ag1.
Note: At the moment this could mean that you are on the "Telehouse East, Juniper 3" gateway.
Alecto
That's not the problem one, so it looks like your problems lie elsewhere.
It is very busy at that time of night though. Might simply be lack of Pn capacity compared with peak demand.
looks ok now - hurrah
all looks ok now :
16-06-2005 17:20:25 1898.9
16-06-2005 17:14:11 1934.5
16-06-2005 17:08:21 1422.4
which is cool
guildwars will be the acid test as it started playing up when playing that
thanks
oh dear bad gateway
spoke too soon :
You are currently connected to the "Telehouse North, Juniper 2" gateway. This gateway is sometimes known as ptn-ag2.
: Evil
curses
ptn, not pth it is pth-ag2 that gives the problems!
Hm, not sure about this gateway checker link.
This is the results from that page:-
[qoute]You are currently connected to the "unknown" gateway. This gateway is sometimes known as ]pte-ag1.
This is the results from traceroute to www.solstans.co.uk (my website hosted on cgi.plus.net)
Tracing route to cgi.plus.net [212.159.3.3]
over a maximum of 30 hops:
1 1 ms 1 ms 1 ms 192.168.0.1
2 40 ms 36 ms 40 ms lo0-plusnet.pth-ag3.plus.net [195.166.128.64]
3 38 ms 37 ms 42 ms ge1-0-0-404.pte-gw2.plus.net [84.92.4.10]
4 41 ms 46 ms 40 ms gi4-0-23.pth-gw2.plus.net [212.159.4.21]
5 42 ms 39 ms 35 ms atm0-1-0.ptb-gw1.plus.net [195.166.129.246]
6 60 ms 50 ms 49 ms vlan18.pri.ptb-gw4.plus.net [195.166.129.130]
7 55 ms 59 ms 63 ms cgi.plus.net [212.159.3.3]
ptn2 is giving me problems as well
well ptn2 is dropping connections as well mainly in guildwars
ummmmm
Maybe its the number 2? Probably the shape of the number two is causing it to get snagged up in a kinked cable between your router/modem and the wall socket Smiley
(Sorry been along day and now in a daft mood)
:lol: :lol:
