speed upgrades
speed upgrades
Hi hopefuly some one can help I have recently requested to have an upgrade from 1mb to 2mb I havr recieved an email from customer support to say that the regrade is done I have done a speed test and get a speed of 968.9kbps which is just above the figures for 1mb any sugestions am I doing something wrong? I use a zoom X3 adsl external modem conected to U S Robotics wireless turbo access point and router with a direct network cable connection to this computer.
1 REPLY
speed upgrades
I realise that you are new to the boards but just as a pointer, it is not a good idea to make the same post in two different sections of the forums. the replies you get may end up getting confused.
In the meantime, if you havent already done so, reboot your modem/router and test again.
