speed touch modem work?
brettking24
Hi im using the voager modem for my pc downstairs and now want to start using a pc upstarirs whenever im not using the other one,im using the same line but only one pc at a time,i have a old speedtocuh 3300 modem,how do i go about using that modem with plus net?
thanks
Moderators note by John (johnessex) Topic moved to the proper forum
brettking24
bump
bump,please help
Not sure if you can sync two ADSL USB Modems at the same time (got a feeling it will fall over).
But to use one at a time, its dead easy. Just install the Speedtouch modem (same as Im using now), whack your username and password in, dial 0,38 - and your in.
Very simple.
If you want them both on at the same time, and it wont work - you need to think of some form of networking....
You can't have two ADSL modems or routers etc connected to the same line at the same time. Even if one of them is switched off.
You will need to unplug the one you are not using at the time from the phone line.
