speed test
speed test
hi everyone,
i used Home Broadband 1mb.
i check speed test today, its only 635kbps. why?
last dec i check speed test is 945kbps.
i thought its should be over 1100kbps?!? Sad
is it any problem with this?
speed test
Does appear to be low but is it regularly low? Have you tried at different times of day?
The BT Speed test instructions here will check your connection before it enters PlusNet and needs to be carried out to rule out faults outside PlusNet's direct control.
If your speeds are still low, raise a "Contact Us" ticket, and give the results of the speed tests that you have recorded over a period of time.
speed test
today is 927kbps. its always up and down but its ok.
if too low all the time then ill post it!
speed test
Since i have had plus net i have never really had much problem with them. Only when i first got it really. My speed test are always 950 960 kbps or higher some times
