speed test results v dsl connection speed
alkan
can someone please explain to this dunce, why my netgear dg 834 router and the bt speed test dsl connection result shows a down stream speed of over 6000kbps while plus net , bt ,speedtest.net and broadbandmax , show around the 3000kbps mark.
have i a problem and if so, is there a fix. or is it a quirk of broadband.
James
Basically, the connection that you have with the exchange has a speed of 6560Kbps, however, BT have profiled your line at 3000Kbps. Max broadband is designed for the profiled speeds to be recalculated every 3 days and your latest calculation was from yesterday.
Hopefully in a couple of days your profiled speed will be raised on the assumption that your synchronisation speed with the exchange remains as it is. Keep an eye on this link:
When that goes up, you should see improved throughput speeds.
alkan
thank you, i understand at last.
