speed test gave me reading of 520k on a 2mb conection!!
brettking24
Help i just done a speed test on my 2mb conection and it came up with -520.50kbps
whats going on?
i was getting
Date Speed Achieved (kbps)
17-09-2005 20:34:12 1808.3
what can i do?
truvoice
same here.
Heres the speeds i got from adslguide
Downstream 433.1 Kbps ( = 0.4 Mbps )
It's like ive gone back in time about 2 years or so
Likewise. Plus continual disconnections and complete unreliability and really slow browsing. Its getting worse. No word from PN, I'll give it another couple of weeks then jump ship if nothing improves. This is just getting plain silly.
brettking24
any news yet?
Has anyone contacted plusnet about this problem?just wondering what they say.
anyone know any good isp i could try?
thanks
lucky !!!!
You lot should consider yourselves lucky, i'm paying for 2meg and after 11 days i'm still only getting 127kbps download, that is when i can get on the net to check it. What is happening is nothing short of a disgrace and Plusnet should hang their heads in shame at the way they are treating good customers. Just try paying them a fraction of your monthly subscription and see what they do, they wouldn't stand for it and would soon boot you off.
I have been monitoring these forums constantly for the past 11 days and have seen enough unsatisfied customers to convince me that this not the right isp for me. But ever patient I am now going to give Plunet 10 more days to get their act together, if not i shall move elsewhere, infact i'd almost sooner do without than be treated in this way!!!! WHAT SAY YOU ALL, STAND UP AND BE COUNTED!!!!
brettking24
messed up or what??!!
just done speed test check this out-
23-05-2006 18:37:22 515.1
23-05-2006 17:40:56 956.4
23-05-2006 17:21:33 1922.9
within 20 min my speed went almost half of what it should be!!
plusnet are one of the worst isp ive used
Have you ruled out exchange contention by completing a BT speed?
For instructions see;
http://usertools.plus.net/tutorials/id/27
Note that you must use the BT login details so that is completed on the BT network only.
If the BT results are good and the Plus.Net is poor, then you can rant at Plus.Net.
Chilly
Yea getting the same here, looks roughly capped to 512kbps but doing a bt speed test is giving me 4300kbps
Same here plus ftp is blocked have carried out the BT SpeedTest which comes out at the correct speed every time I told this to PlusNet and they said I was on the wrong profile and then corrected it, this fixed the problem for all of 2 hours it is now slow again I sent another support ticket and they just said do the BT Speedtest to check my line my profile has been corrected bla bla bla....going round in circles etc
My next step is to take the following advice and get my contract released.
I might cancel my direct debit in the mean time as i'm sure plusnet will drag it all out liek everything else.
http://portal.plus.net/central/forums/viewtopic.php?t=40391
I'm getting some peculiar results too:
23-05-2006 22:29:15 2094.4
19-05-2006 10:39:52 3951.8
14-05-2006 22:56:35 4149.9
06-05-2006 09:56:41 1965.1
05-05-2006 16:55:21 2032.9
04-05-2006 20:06:43 2000.8
So it appears that we are all having similar problems
Oh well this is different.. it's off peak right now yet still 512k speeds... p2p really sucks right now..
I am now getting slightly better speeds. At soon as it was 12am my speeds shots up from 1.5mbps to 3.5mbps.
Is this more evidence of excessive throttling and traffic shaping between peak hours.
Well that is what has happened to me the last few days however ... PAUSE....
hold on.. i'm getting proper speeds now... an hour late tonight maybe... (coincides with msn and aim disconnecting and reconnecting anyone else get this, always had this issue was 12am every night changed to 1am with the clock change)
Defenitely throttled/lack of capacity at peak hours i think as i am now getting 4.8mbps on the Adslguide speed test and 4.6mbps on the BBmax one. This is similar to what i was getting on the BT speed tester a few hours ago.
ook at the difference between last night and this morning
24-05-2006 08:35:32 4239.4
I can understand a 20% difference, but an over 100% difference?
