speed strangness
speed strangness
Like most, I have experienced the slow download speeds other adsl users have reported. About the most I can get form any download site is 7-8kbytes per sec - it used to be 45- 50+ form the best.
The strange thing is, if I check on one of the speed testing sites I mostly get reports of 300kbs which should be giving 30Kbytes + downloads.
Any ideas why the discrepancy ?
Rod
BoneMan
RE: speed strangness
> Rod
Rod,
It might be the site(s) you are downloading from. A lot of sites deliberately throttle their download speeds to give “fair shares” to all. The fact that the test site (which doesn’t throttle the download speed in order to “max-out” your connection) gives you a reasonable result suggests your connection is OK(ish – see other postings for +Net issues) and it is indeed the download site that is causing your disappointing results. My company has an enormous pipe on to the Internet but still I often see download speeds much worse than yours. It’s all down to the other end Smiley.
BoneMan
YOUR ALL CRAZY!..... CRAZY!!!!
Oh, and your all shoes.
Not that kind of speed Mr Tac !
Thanks for the response
Ok on the suggestions I have tried a very wide range
of sites and I'm just not getting the download speeds I used to.
Rod
> Rod
Can you try downloading a file from the file vault (look in the 'My Tools' menu) and let me know what speeds you get? As this is effectively a local download rather than across the internet you should get you highest speeds and a good indication of how the connection is performing.
Regards,
Rob
| Robert Kelly...............Unmetered & ADSL solutions
| Technical Support......................for Home & Business
| PlusNet Technologies Ltd............@ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet ----- +
I tried donloading a file, it went real fast to start with then settled down to around 49k/sec
which is brilliant.
So it looks like the speed reduction is between
plus and the rest of the net.
Regards
Rod
> > Rod
> Hi,
> Regards,
> Rob
Another great night of 5 - 8k downloads...my patience is wearing thin, i had enough of adsl and all it's bullshit... 512k another pile of bullshit from BT, not going to make the same mistake next year.
> > Rod
> Hi,
> Regards,
> Rob
I have tried the above but only get speed of 7.20KB
sec
Can you help me
Martin
