speed checks
buckz
speed checks
what are the recommended speed checks that i should carry out, as i believe my connection isn't as quick as it should be!!
TIA
kreynolds
speed checks
For BT
http://speedtester.bt.com/
For LLU
http://speedcheck.ispconnect.co.uk/speedcheck/
Use own login to test inc PN network or User: testing@dslconnect.co.uk Pass: testing to test the connection to the exchange
For generic speed tests you can use
http://www.mybroadbandspeed.co.uk/
http://www.speedtest.bbmax.co.uk/
http://www.speedtest.net/
buckz
speed checks
Thank you, will use the BT one,
buckz
speed checks
here's the results:
IP profile for your line is - 2000 kbps
DSL connection rate: 448 kbps(UP-STREAM) 3712 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 1761 kbps
what now?
kreynolds
speed checks
Has the connection been stable at 3712 for more than 3 days?
buckz
speed checks
yes, for about a week now
kreynolds
speed checks
sounds like the BRAS profile hasn't been updated or PN haven't received the delta report.
Either way raise a ticket to get your profile changed.
buckz
speed checks
thanks for your help kreynolds
buckz
speed checks
One of the filters that PN supplied with my bt voyager 2110 has just given up the ghost!!!!
Maybe the source of the problem!!
buckz
speed checks
So how to i raise a ticket about the filter, after all I've only had it 12 days!
Will the nice people at PN send me a replacement Cheesy
kreynolds
speed checks
Go to http://portal.plus.net/wizard/index.html?
Under Technical Support click on the following
Broadband Setup - Getting started--->Fixing Broadband Setup Problem--->Broadband Hardware--->I've Already Tried Reinstalling My Hardware--->My Hardware Is From Plus Net.
This'll then open the ticket for you
buckz
speed checks
Thanks mate you've been a real help Cheesy
