sometimes slow 1mb..........................
why? Sad
i got 1mb only 3 weeks! its was fine, but now sometimes slow, sometimes brilliant fast! :?
anyone know, anyone have like that before? :?
im grateful anyone know about it.
cheers
Have you checked your exchange? are the times when it's slow, the same times everyday? I'm wondering if it's contention at the exchange.
User tools will allow you to check the status of your exchange.
im not sure about that, can you tell me? Sad
Can you define slow. High latency(ping times) or slow downloads or both? If its high latency try a traceroute to www.bbc.co.uk see if you can spot where the problem occurs, is it slow over the first few hops?
If its slow downloads have you tried downloading something else, or use DU meter so you can see what your rates really are.
Check out this link User Tools
There is an exchange status check within the site. Just type in your phone number, or local exchange name and it'll tell you the status of your exchange. You might be suffering problems because your connection is becoming contended at busy times, this site will also indicate whether BT have scheduled any work to be performed at the exchange, if there are problems.
i have see User Tools for exchange checker. its green. its no problems.
so well, its fine now.
if happened again, ill let you know.
cheers
