solwise 705 router set up
I have a solwise router and unable to set it up is there a step by step guide? i think its running ver 8.x software
Was this supplied by PlusNet?
Did it come with a manual (on the CD perhaps) or hardcopy?
Have you checked solwise's web site for a downloadable copy of the manual and/or setup instructions?
PlusNet have a page dedicated to getting help with this router available HERE. It has quick-start guides and troubleshooting information.
Plus net supply the SAR 130 not the 705. Go to www.solwise.co.uk and look there.
Are you sure your router is not a SAR715 model or similar as this is the main router model they do?
I have a SAR715+ and have only recently just got this and connected to Plusnet. The manual for this router is supplied on CD from Solwise and as mentioned in the previous post is also on their website under the downloads section. I had no real problems setting my particular model up and Solwise are very helpful if you ring them up for adivce.Smiley
