solid sync, but router internet light is on and off
I have a sync of normally well above 7000Kbps
I've just moved my router to where I can see it and I've noticed that the light which inicates internet goes on and off.
I have a linksys WAG354G.
Does this mean my net connection is constantly on off or does the light flase when it's sending info, to keep the connectio alive etc.
The router is always on but the pcs can be off and the light continues to flash.
A
1 REPLY
Alecto
A, have you looked in the handbook or instruction manual?
Have you looked on Google using the model number and the words "light flashes"? - that is all that we would do to find out for you.
I don't know that one, but my Netgear sync light flashes green when passing data. Wink
