slower adsl? D:
slower adsl? D:
hi
erm my friend wants to get adsl but it appears 512 is out of reach is there anyway he can get slower adsl like tascali offers :?
he wants to go with plusnet but is unable to find the package
thanks for your help
slower adsl? D:
Packages [provided at speeds under 512Kbps are done using trottleing on the connection.
This means the link will only allow a smaller amount of data than is actualy assigned to the line.
As such, you need to be able to get 512Kbps to get the slower speeds.
slower adsl? D:
They may have to wait until the extended reach testing is completed in Milton Keynes. This extends the current max of 5.5->7KM to about 10KM.
When this will be generally available I don't know.
The only other option is cable if that is available in the street.
lowry
slower adsl? D:
I am no great knowledgeable chap on the ADSL scene but from what I have read before here and on other forums like ADSLGuide I have heard the same reply given to that sort of question Wink - and these guys know their stuff Cheesy so it must be the correct answer. Since Tiscali throttle a 512kbit/sec connection to offer the 150k and 256k services it means that it will offer no distance advantages over a standard 512kbit/sec connection ADSL line.
As petervaughan says, trials are currently under way in Milton keynes so I would wait and see how they go and hopefully BT Wholesale will soon extend the reach of their 512k home product to enable you to receive it and have a reliable connection.
Good luck,
matt Wink
