slow speeds
slow speeds
Traceroute Results: View Traceroutes
Traceroute Time (24 Hour): 22:23 to 22:43
Traceroute Duration: 20 minutes
Traceroute Packet Size: 64 bytes
Packetloss in Traceroute?: Yes
Exchange: armadale
Problem: Permanently Slow Data Transfer (Everything is slow)
Other Problem Experienced: pages taking up 2 couple of minuets to open in some sites.slow e-mails.
Duration of Problem: More than 2 weeks
Minimum Speed Achieved On PlusNet Speedtest: 417 kbps
Maximum Speed Achieved On PlusNet Speedtest: 476 kbps
Average Speed Achieved On PlusNet Speedtest: 446.5 kbps
Account: Broadband Easystart - 512kb (50:1)
IP Block Size: Single (default)
Ticket Number: 10497364
Additional Information: speeds up and down like a yoyo.done test in your site showed470 tryed other 2 sites straight away and both were showing 420/410,back to plus site and still showing 468.is the meter correct.
1 REPLY
slow speeds
http://cgi.support.plus.com/exchanges/index.php?exchange=Armadale%20W%20Lothian&notrefresh=yes
Your exchange is amber which means speed variations will occur. See the link for an estimated BT upgrade date and to explain what I am talking about.
Your average speeds are pretty good for 512k ADSL anyway, you always will get fluctuations as you are on a 50:1 contension so the more users (i.e the busier the period) the less bandwidth is available for each individual connection.
Have you tried tweaking your MTU and RWIN values - see the MTR Tweak thread for details.
