slow speeds...should be up to 8Mbps
Can you tell me why I have had connection speeds of no better than 160 to 190 Kbps for the last week ever since I was reconnected after being disconnected for about 48 hours
Plusnet Staff
Plusnet Staff
Fixes: 159
As you are on the LLU service one of the first steps to resolve problems is to reduce the connection speed. I have altered back to the normal profile for you now. Please let us know if you start to have connection problems again.
 Chris Parr
 Plusnet Staff
iam exactly the same downloading at 350+ on thursday , since then i am lucky to get 50+kps
