slow speed and eratic latency in games
Traceroute Results: View Traceroute
Traceroute Time (24 Hour): 22:26 to 22:28
Traceroute Duration: 2 minutes
Traceroute Packet Size: 64 bytes
Packetloss in Traceroute?: Yes
Exchange: LWWAT
Problem: Latency / Choke
Duration of Problem: More than 1 month
Minimum Speed Achieved On PlusNet Speedtest: 0.00 kbps
Maximum Speed Achieved On PlusNet Speedtest: 0.00 kbps
Average Speed Achieved On PlusNet Speedtest: 0 kbps
Account: Broadband Easystart - 512kb (50:1)
IP Block Size: Single (default)
Ticket Number: None
Additional Information: None
something has screwed up here as this keeps telling me i have 0.00kbps min and max speeds!
1 REPLY
The plusnet speed tester can sometimes do that. If you have https in the URL, remove the s and try again. That sometimes works. Firewalls can also interfere with the speed test so try disabling it temporarily to see if that helps.
Failing that, use the ADSLguide speedtest and to test pings & packet loss, use WinMTR.
Note: your average ping times in the supplied traceroute look fine to me.
