slow connection
slow connection
my adsl connection is really slow. ive changed my mtu settings using dr tcp....but still my upload and download speeds are really low..
any ideas Huh
RE: slow connection
> any ideas Huh
Direction
Actual Speed
True Speed (estimated)
Downstream 60 Kbps (7.5 KB/sec) 64 Kbps (inc. overheads)
Upstream 38 Kbps (4.8 KB/sec) 41 Kbps (inc. overheads)
this is the speeds im getting.. results from adslguide.org
RE: slow connection
Try changing your Receive Window value to 12762, see if that helps.
Dave Allan
RE: slow connection
Is your connection always like this or just today?
I usually get 470/240 speeds, but this afternoon speeds are low, pings bad and loads of packet loss. Based on tracerts it seems to be with the plusnet routers.
RE: slow connection
Yes it's really bad this everning have a look at this
Downstream 441 Kbps (55.1 KB/sec) 476 Kbps (inc. overheads)
Upstream 35 Kbps (4.4 KB/sec) 37 Kbps (inc. overheads)
RE: slow connection
Yeah, I am getting reasonable download but I only got about 7 k/sec upload. I thought it was just me though.
Bill
