slooooooow speed
slooooooow speed
My speed test is showing slower than ISDN. I am not going to pay for 8mb service and get 128 kb...
Whats going onHuh
slooooooow speed
You don't pay for 8mbps service, you pay for up to 8mbps Wink
You need to tell us a little more though for any meaningful answer.
What package are you on? What is your useage to date?
Are there any other symptoms, eg noise on the line?
Historically have oyu had any problems?
What are your lie stats?
Plusnet Staff
Plusnet Staff
Fixes: 159
slooooooow speed
I've just had a look at your account from here and can't see any reason for a slowdown. Can you post the results of a BT speedtest in here, www.speedtester.bt.com
Might also be worth rebooting your router as it looks like its been connected for quite a long time.
 Chris Parr
 Plusnet Staff
slooooooow speed
I do appear to be running slow also tonight, but only HTTP all else is fine.
