site access problem
636steve
site access problem
I was ftp'ing to a server when it lost connection. Since then I have been unable to connect to the server via ftp or the interent. Can see the web site at work but not from either of my home computers.
Have had a ticket in since 27th july and had one answer but now waiting for aother response!!
The owner of the server say's he isn't blocking my ip, and I still can't connect even if I disable the firewall at my end.
I need to connect ot this server from home. Any ideas?Huh
Merlin
site access problem
can you ping it?
site access problem
Have you tried both passive and active FTP connections? There should be a setting in your FTP client to select this.
Also try a different FTP client.
Merlin
site access problem
Good point about passive/active especially if a local firewall has been updated or installed. You could also do a trace command from a the command prompt type in 'tracert ftp server address' where ideally the ftp server address is an ip so that dns is eliminated.
