should i be on 2mb?
should i be on 2mb?
Downstream
Speed: 1152 kbps
Line Attenuation: 39db
Noise Margin: 31db
Upstream
Speed: 288 kbps
Line Attenuation: 11db
Noise Margin: 31db
These are the stats from my router. Are these good enough for 2mb? Previously Plausnet said I could only get 1mb...
1 REPLY
should i be on 2mb?
Should be fine, max downstream Attenuation is 43 dB so you are within that. Your SN margin is good also at 31 dB. Ask plusnet for a whoosh test telling them your figures. If they get similar figures they can do a manual regrade even if BT database says you cannot get 2MB. You will need to ask them for this though as it is not automatic.
